Advanced Member Denis Posted April 2, 2014 Advanced Member Report Share Posted April 2, 2014 1. Is there a way to paint over an object once you assign a shader to it? 2. How do you get back to the default grey shader? Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted April 2, 2014 Reputable Contributor Report Share Posted April 2, 2014 (edited) First it would help to answer your questions if you tell us where you are in your workflow. Voxel, Surface, Merging to the paint room etc... Yes you can paint over a shader if you are in Surface mode. Switch to the paint room and use the regular paint tools available. You are vertex painting without the need of a uv set but you will have to have a high polygon count to have more quality in the painting. The more vertices you have the finer the painting. """Important"" Never paint on Layer "0" it is reserved for 3DC use... In the paint room hide the layer/layers that has the paint information or delete the layer/layers. The shader will be shown in it's default state whether the grey shader or any other shader. Answers based upon information given. I did not talk about baking (merging) the shader and paint layers to the paint room if you need them. Edited April 2, 2014 by digman 1 Quote Link to comment Share on other sites More sharing options...
Javis Posted April 3, 2014 Report Share Posted April 3, 2014 David, you are on a roll! Thank you good sir, your help, and YOU, are very much appreciated. Quote Link to comment Share on other sites More sharing options...
