Advanced Member stevecullum Posted October 13, 2008 Advanced Member Report Share Posted October 13, 2008 I have made an error of judgement with a model and need to re-create the UV maps, seperating out portions so I can have separate textures. Is there a way I can transfer the displacements and painting I have done so far on my original model, onto the new one with different UV's and continue my work? Thanks for any advice... Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted October 17, 2008 Report Share Posted October 17, 2008 Well you can use File > Import UV Set and select the object with the correct UVs in it. Not sure if that helps you. Quote Link to comment Share on other sites More sharing options...
Advanced Member stevecullum Posted October 17, 2008 Author Advanced Member Report Share Posted October 17, 2008 Thanks Phil. I resolved the issue now. Its handy to know about the UV import feature, although it didn't help this time around. Quote Link to comment Share on other sites More sharing options...
