Member Upon Infinity Posted February 15, 2015 Member Report Share Posted February 15, 2015 I accidentally posted this in the wrong section. Reposting here. Hi, What's the best way to fix the inner shell issues that leave black patches on your model in the paint room after baking? I've tried making those areas higher poly density as well as adjusting the inner shell distance but it seems to be quite common on very detailed models. Advice? Quote Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted February 15, 2015 Contributor Report Share Posted February 15, 2015 From experience , playing with the distance values solves this. Quote Link to comment Share on other sites More sharing options...
Member Upon Infinity Posted February 15, 2015 Author Member Report Share Posted February 15, 2015 Yes, normally this works with lower detailed models. However, with higher detailed models, I seem to get to a point where I can eliminate most of them but not all, and then any further increases to distance actually starts increasing the problem. I was just curious if there are any good workarounds for this. Or, if there is a good high poly workflow video I can get some hints from. It's quite frustrating and I've already spent hours on it. Quote Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted February 15, 2015 Contributor Report Share Posted February 15, 2015 Check this one from 7 minutes , it may give the solution. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted February 15, 2015 Reputable Contributor Report Share Posted February 15, 2015 (edited) If you can share your model for others to look at that would be helpful as we can examine the file as well... You can pm me a link to download the file if you can not share the file on this thread. You can use spheres of influences on the trouble areas... Go inward so far then use the spheres of influence. This avoids the problem of setting the inner or outer cage too far to cover all areas... The use of this function is in the below tutorial by AnbRanger... Edited February 15, 2015 by digman Quote Link to comment Share on other sites More sharing options...
Member Upon Infinity Posted February 16, 2015 Author Member Report Share Posted February 16, 2015 Thanks, guys, it looks like the spheres of influence was what I was looking for. Didn't even know this feature existed and actually, it's pretty helpful. Thanks again. Quote Link to comment Share on other sites More sharing options...
