Advanced Member Paint Guy Posted October 17, 2008 Advanced Member Report Share Posted October 17, 2008 Andrew, I just ran into a problem or bug. The UV Preview window will not expand /open. I clicked the little "pushpin" and it opens the window about 2mm, then if I click it again it closes to about 1mm in height. It was working fine before when I ran those UV tests. Sorry you're not going to like me soon. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted October 18, 2008 Report Share Posted October 18, 2008 Andrew, I just ran into a problem or bug. The UV Preview window will not expand /open. I clicked the little "pushpin" and it opens the window about 2mm, then if I click it again it closes to about 1mm in height. It was working fine before when I ran those UV tests.Sorry you're not going to like me soon. Try to resize it down. Try to pin/unpin it until you will be able to see resize cursor near the bottom of the small 2 mm window. Quote Link to comment Share on other sites More sharing options...
