Member Sable0411 Posted January 18, 2016 Member Report Share Posted January 18, 2016 I've finally gotten to the texturing stage of my first model *which, the topology isn't great, but for this first model that will be fine* but... 3D Coat is starting to act a bit bizarre. For awhile, it refused to change alphas, it was locked on some weird... star thing, and no matter what I did it stayed on it. That just corrected itself for no discernible reason, but the brush itself is still acting weird. Primarily, the pressure indicator is now upside down. I haven't seen anyway to restore brush settings to factory defaults, so if anyone can aid with that, it would be much appreciated. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor Solution digman Posted January 19, 2016 Reputable Contributor Solution Report Share Posted January 19, 2016 (edited) First problem with the star alpha could have been related to this problem the user had in another thread. You had selected the Strips star alpha. http://3dcoat.com/forum/index.php?showtopic=18775 The pressure indicator, not sure what is happening there. The only thing I know to do for now is check under the brush options panel, check the "Depth Modulator". If it is a minus number your pressure indicator inside the yellow ring will be inverted. Edited January 19, 2016 by digman Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted January 19, 2016 Reputable Contributor Report Share Posted January 19, 2016 I might have misunderstood what you meant by pressure indicator, could you please explain further... Quote Link to comment Share on other sites More sharing options...
Member Sable0411 Posted January 19, 2016 Author Member Report Share Posted January 19, 2016 I might have misunderstood what you meant by pressure indicator, could you please explain further... Well... I might have simply used the wrong word, but the kind of red curve that is visible to indicate the strength of the brush. That was upside down, for whatever reason. And definitely still is. When I increase the strength, it flips back to the right side, but then it promptly turns back around. It isn't affecting my work honestly, but it is something of a graphical error of some kind in the interface. As far as the other thing, that probably was it, but I must of hit the right thing to shut it off as I can now switch between brushes without any problems. Quote Link to comment Share on other sites More sharing options...
Javis Posted January 20, 2016 Report Share Posted January 20, 2016 Hi. That's caused by brush rotation, is to help indicate which direction you brush is rotated. You can rotate with 0 and 9. Sent from my SM-G900P using Tapatalk Quote Link to comment Share on other sites More sharing options...
Member Sable0411 Posted January 20, 2016 Author Member Report Share Posted January 20, 2016 Ah, okay... I wonder how I did that, I don't recall ever making such a change. Guess I'll just poke around until I can switch it back, heh. Thanks for the replies, I'll keep all of this in mind for future projects. Quote Link to comment Share on other sites More sharing options...
