Member eskay Posted November 19, 2016 Member Report Share Posted November 19, 2016 Is there a way to lock the radius of the radial symmetry whilst using a brush in the sculpt room? For example looking at the model in the Top down view where the circularity of the radial symmetry is visible I want to be able to lock the radius so that a brush stroke will follow the circumference. Is this possible? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 2, 2016 Report Share Posted December 2, 2016 Alternatively, you turn on the "2D Grid" and "Snap To 2D Grid", then rotate it as needed with the top right corner options. Quote Link to comment Share on other sites More sharing options...
Member eskay Posted December 2, 2016 Author Member Report Share Posted December 2, 2016 I must be missing something in your reply but how do I both rotate the 2D grid and draw at the same time? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 3, 2016 Report Share Posted December 3, 2016 Sorry i misunderstood. Circle lasso is not useful ? Quote Link to comment Share on other sites More sharing options...
Member eskay Posted December 4, 2016 Author Member Report Share Posted December 4, 2016 (edited) No the lasso tool is not what I was looking for. Say I wanted to carve into the mesh six arcs. The radial symmetry tool allows me to cut once and have it repeated an additional five times however I have to have a steady hand and eyeball it to try and get a carve that follows the true arc curve of a circle of fixed radius. Currently the radius of the radial symmetry tool varies from the start to the end of the brush stroke. Edited December 4, 2016 by eskay Quote Link to comment Share on other sites More sharing options...
