New Member Ariaxu Posted November 22, 2016 New Member Report Share Posted November 22, 2016 Hello so recently i decided to try out 3d coat as i like the painterly effects it can produce however i cant seem to be able to create layers whenever i click 'add layer' list of layers just flashes quickly and jumps to layer 0 if i have any colors on the existing layers 1/0, after clicking 'add new layer' those colors will disappear it seems like i can only create layer 0 which overrides others? im not sure what is the problem here also as you can see on the screenshot my colors on texture editor are completely off ive tried this with different objects, all had same results Quote Link to comment Share on other sites More sharing options...
Carlosan Posted November 23, 2016 Report Share Posted November 23, 2016 I saw this situation few days ago In which app do you created this model ? Can you export it on another format as fbx ? which are your import settings ? Quote Link to comment Share on other sites More sharing options...
