New Member nameless Posted January 10, 2017 New Member Report Share Posted January 10, 2017 1. So I've imported sketchup model to 3dc and wanted to clean up. The top face had lot of random small triangles, so I deleted them by brush slect/del key, but it leaves a hole. In blender, I'd just select two edge loops and bridge. However, in 3dc, not only I can't make edge loops (select edge, press L, nothing happens, but R for ring select works), but I can't find bridge option - I found Cap, but it seems to be suited for closing simple holes (with nothing inside) I've attached .obj file if anyone would like to check personally 2. Another question is retopology and selecting edges. When importing mesh for retopology, 3dc gives you 4 options, 3 of which seem to be automatic and give me no possibility to select edges (with Select tool enabled). I'm confused. The option where 3dc doesn't retopo automatically and lets you do work manually, is where I can actually select edges and work on them. I thought I could refine manually on those 3 auto retopo options? 3. When importing, sometimes model is so small that can't be seen on viewport, is there a way to tell 3dc to scale automatically to fit viewport? untitled.obj Quote Link to comment Share on other sites More sharing options...
New Member nameless Posted January 10, 2017 Author New Member Report Share Posted January 10, 2017 4. Forgot to ask, when I apply smart shader with dirts/scratches that rely on curvature map, can I manually refine them with brush? I know I can adjust those with sliders in smart shader parameters, but I want to use brush. Or do I have to rely on external painting software like subst. painter? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 11, 2017 Report Share Posted January 11, 2017 Hi ! We have been asking Andrew for a bridge type of tool to join polygon strips. Andrew at one time say he would like to add more modeling tools in the retopo but for right now, the Paint room updates are on the front list. In 3D-coat you can "drag" new faces from edges and weld them automatically when they meet vertices. The tool is called Quads Tool and here's an example how it works: https://youtu.be/6-hsouZQqOY?t=1m11s So basically it's a way to extrude edges pretty fast and it's great for strip modeling. ---------------------- Added on newest versions: Bridge Tool under Selected > Bridge Quote Link to comment Share on other sites More sharing options...
