Advanced Member Gary Dave Posted January 24, 2017 Advanced Member Report Share Posted January 24, 2017 Whenever I bake using the default material, the result always has a cavity map, much like the result of the "Clay2" material. I am not using clay2. I am only using default. Anyone have any ideas? Just to clear some things up, this is not an AO issue, the far right image you see above is just displaying what's on the base object layer. No other layers are visible. (and on that note, I thought occlussion baking in the paint room was supposed to recognise normal maps? I can't get it to work at all, only does basic geo AO for me.) Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 25, 2017 Report Share Posted January 25, 2017 I cant replicate... is this option off ? Quote Link to comment Share on other sites More sharing options...
Advanced Member Gary Dave Posted January 26, 2017 Author Advanced Member Report Share Posted January 26, 2017 On or off, it's always the same, low values, high values, no difference. Tried it on a different mesh piece too. I also created my own shader/material in the sculpt room and made sure it had to extra settings, just colour, but the bake is always the same, it always seems to include cavity on the objects layer in the paint room. AO is completely separate. For now I'm just deleting that paint layer and re-baking AO, and then boosting it a bit in photoshop. It gives me what I want, though a bit of a hassle. I'll be able to test it again in a week or two on my proper computer, I'm on a laptop at the moment with integrated graphics so I wonder if that has something to do with it. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 26, 2017 Report Share Posted January 26, 2017 Hi Can you test this issue using the latest version ?http://3dcoat.com/forum/index.php?/topic/19525-3d-coat-47-beta-testing-thread/ Thank you ! Quote Link to comment Share on other sites More sharing options...
Advanced Member Gary Dave Posted January 27, 2017 Author Advanced Member Report Share Posted January 27, 2017 Hey, thanks for the response. I only use whatever the Steam version is running (currently 4.7.06). If you're on a later version and can't replicate the issue then that's good enough for me. 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 28, 2017 Report Share Posted January 28, 2017 On 2/15/2015 at 8:38 PM, fuzzzzzz said: Steam can support Beta program, there is a tab under 3dcoat properties, many app use it to provide preview and beta program Example Open the steam client and go in Library. Right click on the app and select properties. 2 Quote Link to comment Share on other sites More sharing options...
Advanced Member Gary Dave Posted January 30, 2017 Author Advanced Member Report Share Posted January 30, 2017 Much appreciated. I shall try it later today and report back. Quote Link to comment Share on other sites More sharing options...
