Member Pebble09 Posted August 2, 2017 Member Report Share Posted August 2, 2017 Working in a team we often have to share smart materials or brushes that someone has created. This then has to be copied from someones documents location to a library we have on the server and then into whoever needs it's documents folder. It would be much more efficient to have everyone sourcing their brushes/materials all from the same location which ideally would be our library location. Is this possible? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 2, 2017 Report Share Posted August 2, 2017 Create Extension tool to share any 3DC content is not enough ? Quote Link to comment Share on other sites More sharing options...
Member Pebble09 Posted August 2, 2017 Author Member Report Share Posted August 2, 2017 It can work, it's just faster to have my entire team sourcing from the same location as this would automatically update every time they restarted 3Dcoat. That way we can have access to each others brushes/materials without even asking. If it's not possible I suppose we'll stick to the manual method. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 2, 2017 Report Share Posted August 2, 2017 Is this post useful for you ? There is an open feature request about this topic, if you want to add your opinion. Thanks. 0001045: Add an option in the preferences to select the path that you want to use for the user folder http://3d-coat.com/mantis/view.php?id=1045 Quote Link to comment Share on other sites More sharing options...
Member Pebble09 Posted August 2, 2017 Author Member Report Share Posted August 2, 2017 Ah perfect thank you! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 2, 2017 Report Share Posted August 2, 2017 Glad to help. Quote Link to comment Share on other sites More sharing options...
