New Member Darkness Seeker Posted May 3, 2018 New Member Report Share Posted May 3, 2018 Good evening I'm new to the program and I was finishing a little texture in order to see what the program was capable of, and ended it like this: https://i.imgur.com/iMIXlJt.png And suddenly, I don't know what happened, it suddenly turned into this: https://i.imgur.com/vaLhojP.png Even if I open the file I had before the error showed up, it still shows the texture completely messed up. What can I do?! Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted May 3, 2018 Report Share Posted May 3, 2018 If you was importing external normalmap, it is possible you changed how normal map applied, look Edit->Preferences->Normal map software preset Quote Link to comment Share on other sites More sharing options...
New Member Darkness Seeker Posted May 3, 2018 Author New Member Report Share Posted May 3, 2018 4 minutes ago, Andrew Shpagin said: If you was importing external normalmap, it is possible you changed how normal map applied, look Edit->Preferences->Normal map software preset It just says "Unknown" on the menu: PD: I tried to save the texture, and although it came super dark, I managed to edit it later on phtoshop to keep a copy of my work, so it seems it has something to do with the viewport more than with the actual file, as the image was "clean" but almost black. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted May 3, 2018 Report Share Posted May 3, 2018 I see problem in normalmap. Please send scene to support@3dcoat.com and I will help. Quote Link to comment Share on other sites More sharing options...
