New Member sol Posted July 7, 2018 New Member Report Share Posted July 7, 2018 Hello everyone I am recently practicing 3Dcoat, mainly using it to draw hand-painted textures. I found there is a convenient and useful function called “ light baking tool “, but I can’t make it successfully by myself though watching varies Tutoria . Please refer to the video, the function did not work successfully. There’s no response to the clicks. Could anyone help me to solve the problem ? Thanks a lot. https://www.youtube.com/watch?v=44RU1pb8HEo&feature=youtu.be Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted July 7, 2018 Reputable Contributor Report Share Posted July 7, 2018 Seems like re-installing 3D Coat (try the latest Beta, they are pretty stable and I just used the Light Baking tool last night...so it works) might help fix it. Maybe delete the OPTIONS.XML file beforehand. That can sometimes get corrupted and exhibit bug like behavior. It's located in the "MyDocs/3D Coat 4.8" directory Quote Link to comment Share on other sites More sharing options...
Reputable Contributor Solution AbnRanger Posted July 7, 2018 Reputable Contributor Solution Report Share Posted July 7, 2018 This post was recognized by Carlosan! AbnRanger was awarded the badge 'Helpful' and 1 points. Also, try to make sure you update your graphic card drivers, since the Light Baking tool uses the GPU. Another thing you could try is to use the DX version. Sometimes the OpenGL version can have glitches. DX has always been very stable for me, so it's the only one I use. Seeing a black background tells me there is something going wrong with the viewport. Quote Link to comment Share on other sites More sharing options...
