Member Zchu Posted July 25, 2018 Member Report Share Posted July 25, 2018 Hi everyone. Looking to purchase 3dcoat soon since my trial ran out. However there are a few things I was not able to figure out when using, nor could i find an answer when searching on these topics. 1) Where is the Object list? And can you select objects to be painted? I do this with Mudbox right now. There is an object list and you select which object in a mesh you want to paint, or select multiple objects to paint on all of them. I wanted a similar function in 3d coat. For example this head mesh I am working on has 3 seperate objects in it, head, lashes and eyeballs. If i wanted to just paint on the eyeball I could select only that from the object list as shown below: If I wanted to paint on all the objects at once (usually to fix seams, ect) I can select them all like this: 2) Painting on UV edge without seams. This is something I recently discovered in substance painted and was wondering if it was possible in 3d coat. Basically when painting in the UV islands you have the option of having it where when you paint near an edge it will also paint to corresponding UV island it connects to without seams. Here is an example, since it is hard to explain: Thanks everyone! Quote Link to comment Share on other sites More sharing options...
Member Zchu Posted July 25, 2018 Author Member Report Share Posted July 25, 2018 Update: (Sorry for double post, could not edit original) I found solution for question 1. I object list was under Windows>Popups> Paint Objects. And while you can not select an object to paint, you can lock all the other objects and only leave the one unlocked you want to edit. A bit odd, but it works. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 25, 2018 Report Share Posted July 25, 2018 Hello Painting on UV edge without seams is not possible at this moment, sorry. 1 Quote Link to comment Share on other sites More sharing options...
Member Zchu Posted July 25, 2018 Author Member Report Share Posted July 25, 2018 53 minutes ago, Carlosan said: Hello Painting on UV edge without seams is not possible at this moment, sorry. Thank you for letting me know. Hope it is something we get in the future. Quote Link to comment Share on other sites More sharing options...
