3D Coat Forums
bigrip
[Bug] no brush, no layer pick with "h" key
hi
when i open my file i can do nothing, i only have the normal Windows mousepointer no brush and i can not pick a layer with the H key.
i use version 4.8.20 (dx64) steam version . i try the opengl version and the non steam version too.
i try version 4.8.25 with the same problem.
when i presss the left mouse button over my mesh   the ("pick point" see the picture") i think it´s always on  0.0.0 position.
only if i use the cut off tool ,cut a hole in the mesh and  undo, then i see my brush and all is working normal.
Edited by bigrip
ok i found out when i delete the "3D-CoatV48" folder in the documents  folder it works
but when i copy my selfmade models back  in the  Documents\3D-CoatV48\VoxStamps\Objects folder
the problem is back
Hi
Check the models on other app to know if everything is ok, may be ngons or holes...
i have it ,its not the  models
when i open my File with / File - open recent /,  the problem is here
when i   do / File - open / there is no problem
Sorry i cant replicate this issue, but some users report issue with fbx files import process.
Are you importing fbx or obj ?
Please open a new fresh and empty scene, load the model and press shift+a (frame).
Do you see any model ?
May be the scale is huge ?
Geometry > Edit Scene Scale. Are values correct ?
hi
i reinstalled Windows  ,have newest driver´s.
Scene scale is way off i think
x-shift -6.71  ,     y-shift -3.20  ,   z-shift   -2.16
SceneScale 13.83
i set it to x0, y0, z0, Scenecale 1,save to new file but the Problem is still there.
i attached the file, Maybe something is wrong with my pc.
traum.3b
Bug confirmed and reported.
Meantime please export the file as fbx2014.
Thx.
