New Member InternetFriend Posted November 27, 2018 New Member Report Share Posted November 27, 2018 Any time I attempt to bake from the retopo room the result is empty normal map and diffuse layers. To troubleshoot I created the simplest bake scene I could, a voxel or surface cube and an unwrapped plane, and even that fails in the way I described. Updated to version 4.8.25 (educational) and still have this problem. The same low poly and high polys exported to Handplane bake just fine. Any suggestions? I've watched several videos and have tried to follow the same steps and get nothing. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted November 28, 2018 Report Share Posted November 28, 2018 Hi I was testing similar scene and can bake without any trouble -using version 4.8.28- Try using this settings Quote Link to comment Share on other sites More sharing options...
