Advanced Member akira Posted March 14, 2009 Advanced Member Report Share Posted March 14, 2009 It's a known issue that when a stroke is self-overlapped, there will be a "valley" effect at the intersection area. But now I have a new idea to improve it. Let me explain the valley effect more clearly with the extrude tool of voxel mode: You can analogize the height of the stroke in this picture to the color alpha of the stroke in the first picture. I can 90% be sure that the current alpha operation of the intersection area might be: pseudo code: if overlapped do ( colorAlpha = max(previousAlpha, currentAlpha) ) What I ask for is to add an option to have another alpha operation method pseudo code: if overlapped do ( colorAlpha = min(1.0, previousAlpha + currentAlpha) ) With above operation it will be much easier to fill an area with one single stroke. It's a little difficult to do so with current alpha operation method: regards, akira. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted March 14, 2009 Report Share Posted March 14, 2009 Yes, really first pseudo-code is used for standerd pen. But second is also used - for airbrush pen. So adding slightly advanced spacing can solve the issue. I have already made in VS, maybe I will do it in DP also. Quote Link to comment Share on other sites More sharing options...
Advanced Member akira Posted March 14, 2009 Author Advanced Member Report Share Posted March 14, 2009 Yes, really first pseudo-code is used for standerd pen. But second is also used - for airbrush pen. So adding slightly advanced spacing can solve the issue. I have already made in VS, maybe I will do it in DP also. Thank you Andrew, really hope to see this on standard pens, the shape of the airbrush pen is a little blobby to me. About the airbrush, after tested it in DP mode, I found out that it works only on layer 0, if you paint on any blank area in other layers, it's not working. regards, akira. Quote Link to comment Share on other sites More sharing options...
