Member dexsoft Posted July 20, 2019 Member Report Share Posted July 20, 2019 I have problems in retopo when I want to make hard edge loop by doubleclick on edge. It works fine when edge is not UV cut edge and whole loop becomes hard edge. But when I double click on edge which is part of UV cut edge it refuses to mark whole loop like hard edge. Instead only double clicked edge is marked as hard. So I need to remove cut from edge loop, then double click again with hard edge tool to make it hard and then to cut edge loop again. Maybe I am doing something wrong but it looks like a bug to me. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted July 21, 2019 Reputable Contributor Report Share Posted July 21, 2019 8 hours ago, dexsoft said: I have problems in retopo when I want to make hard edge loop by doubleclick on edge. It works fine when edge is not UV cut edge and whole loop becomes hard edge. But when I double click on edge which is part of UV cut edge it refuses to mark whole loop like hard edge. Instead only double clicked edge is marked as hard. So I need to remove cut from edge loop, then double click again with hard edge tool to make it hard and then to cut edge loop again. Maybe I am doing something wrong but it looks like a bug to me. It's not a bug. It's just a feature Andrew never added. I presume it's because he assumes the user does their Retopo first and applies UV's afterward. But, there are plenty of occasions where we need to make some tweaks even after doing the UV's. Please send the request to support@3dcoat.com. I've been intending to do the same, but among other issues or requests, I forget. Quote Link to comment Share on other sites More sharing options...
Member dexsoft Posted July 21, 2019 Author Member Report Share Posted July 21, 2019 Hm, I always make my uvs first and then mark hard edges to make baking. It looks I reverse order to avoid this Quote Link to comment Share on other sites More sharing options...
