LucasGnR
Retopo: Smooth brush intensity problem
I was just using Smooth in Surface mode and it was fine. Have you tried the different pressure sensitivity options in the E panel (press E on your keyboard)?
Oh the regular brush in retopo. You have to hold shift for smooth. I just spent the last 2 days in there and it seemed normal. I'm not sure the Brush tool ever had an intensuty in the Retopo room. Unless I'm misunderstanding.
The smooth brush works fine, the problem is that it seems that the intensity value always remains at maximum, even setting the value to 0 (shift + RMB + mouse down)
10 hours ago, Falconius said:
There is quite a lot to the smooth brush that you might not have known, you might want to check out the video.
needs to be in the retopo room
