Member als Posted March 23, 2009 Member Report Share Posted March 23, 2009 How to import all of this quickly and apply it to geometry with 100 precision? I would suggest it would be great if you can import all the layers in one go (like photoshop layers, but not layers, separate files), based on naming convention. I also need a circle paint, for example to map a watch to a hand, or necklace. Something like ticket seem plugin for maya. Choose edge on model, then choose images, and it paints them. I know you can do this with curves, etc. but just in case when you need it spot on and precise. Or this is already possible? Thanks Als Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted March 23, 2009 Report Share Posted March 23, 2009 How to import all of this quickly and apply it to geometry with 100 precision?I would suggest it would be great if you can import all the layers in one go (like photoshop layers, but not layers, separate files), based on naming convention. You can import all maps using File->Import/export menu. I also need a circle paint, for example to map a watch to a hand, or necklace.Something like ticket seem plugin for maya. Choose edge on model, then choose images, and it paints them. I know you can do this with curves, etc. but just in case when you need it spot on and precise. Or this is already possible? Press 'E' - there is circle icon. Try it. Quote Link to comment Share on other sites More sharing options...
