Member LypsiK Posted April 4, 2009 Member Report Share Posted April 4, 2009 hi, is there a way to import a 4-6M polygone mesh to make a new topology? it say out of memory when I try to import a big mesh : ((. I have only 3go ram Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted April 5, 2009 Report Share Posted April 5, 2009 Have you tried to import it as reference mesh? When it tells "Out of mem"? Have uou importd low poly mesh, then imported big mesh and it crashed? Quote Link to comment Share on other sites More sharing options...
Member LypsiK Posted April 6, 2009 Author Member Report Share Posted April 6, 2009 i don t understand how to use import big mesh lol. In zbrush, I export midpoly mesh with uv in a folder. Then i export hight poly mesh in an second folder. The 2 mesh have the same name and the same material (.mtl) but nothing happend. Quote Link to comment Share on other sites More sharing options...
Member LypsiK Posted April 6, 2009 Author Member Report Share Posted April 6, 2009 ok after many test i ve find how to use "import big mesh". But it tell out of memory when it try to import mesh with 5M poly : (( Quote Link to comment Share on other sites More sharing options...
Advanced Member lc8b105 Posted April 7, 2009 Advanced Member Report Share Posted April 7, 2009 Hi LypsiK, If you only want to do retop, please use "File"-"Import reference mesh": Quote Link to comment Share on other sites More sharing options...
Member LypsiK Posted April 7, 2009 Author Member Report Share Posted April 7, 2009 with the import reference tool I can t import mesh up to 1,5M poly : (( Quote Link to comment Share on other sites More sharing options...
