Member KHU Posted April 9, 2020 Member Share Posted April 9, 2020 Hi, Me again. When I try to mirror my object from left to the right, it's just disappeared. I don't know why, could you help? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/24416-solved-symmetry-problem/ Share on other sites More sharing options...
Carlosan Posted April 9, 2020 Share Posted April 9, 2020 Hi, hope it help On 2/3/2018 at 1:48 PM, Falconius said: There is a Symm Copy option under the geometry menu. To use it turn symmetry on, and then turn on whatever planes you want it to copy to and then hit the button. It tends to copy the object side you last worked on, so if it copies the wrong way just hit undo alter a bit of the object on the side you want copied, hit undo again and then use it. 1 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/24416-solved-symmetry-problem/#findComment-166339 Share on other sites More sharing options...
Member KHU Posted April 10, 2020 Author Member Share Posted April 10, 2020 Nice! Thank you! 1 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/24416-solved-symmetry-problem/#findComment-166355 Share on other sites More sharing options...
