New Member alieser Posted May 22, 2020 New Member Report Share Posted May 22, 2020 I'm trying to use custom alphas I made to use them as stamps on objects, however when I select any of these, and try to use the airbrush with stamp drag mode, nothing happens - no effect on object whatsoever. I tried other modes like constant pressure, and had the same result. When I switch to one of the default alphas, it seems to work fine. Another thing I noticed is that in my custom alphas, the depth controller looks to be set to 0 in the cursor, and I cant control it with ctrl+right click. However the depth input in the ui is not 0. (see image) What am I doing wrong here? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 22, 2020 Report Share Posted May 22, 2020 Hi Hope this help On 4/17/2020 at 1:21 PM, sprayer said: Try to save just custom alpha with transparency to PNG and import it as brush. 1 Quote Link to comment Share on other sites More sharing options...
New Member alieser Posted May 22, 2020 Author New Member Report Share Posted May 22, 2020 37 minutes ago, Carlosan said: Hi Hope this help Thanks you so much! Works perfectly. 1 Quote Link to comment Share on other sites More sharing options...
