New Member Alex Podverbny Posted August 8, 2020 New Member Report Share Posted August 8, 2020 Scrape tool seems to ignore depth / pressure settings, and behaves as if depth is at 100% -- here is example video, depth is set to 1% and I'm slightly touching stylus. All others tools (well, airbrush / voxel clay / extrude) behave as expected, so it's not system/stylus issue. Maybe it has something to do with voxel size (it's kinda large, see the mesh at the end of video). Or maybe I'm just doing something wrong... Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 8, 2020 Report Share Posted August 8, 2020 Hi Restart and then create a new Box primitive. Test Scrape tool again. Is working fine ? Quote Link to comment Share on other sites More sharing options...
New Member Alex Podverbny Posted August 8, 2020 Author New Member Report Share Posted August 8, 2020 22 minutes ago, Carlosan said: Restart and then create a new Box primitive. Test Scrape tool again. Is working fine ? Nope. Example from video was done this way -- started 3D coat, created box primitive, res+ couple of times, did some voxel-clay things, then tried to scrape those things. I vaguely remember older versions (4.8.x) didn't have this issue -- 1% depth scrape did very small changes even with mouse. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 8, 2020 Report Share Posted August 8, 2020 Bug confirmed and reported, thx for point it up. Quote Link to comment Share on other sites More sharing options...
