Member Fuzatron Posted August 21, 2020 Member Report Share Posted August 21, 2020 I'm trying setting up a render in Cinema 4d and would like to use the same Environment Map (the parking garage) that I'm using in 3D Coat. I haven't been able to find a way to export them. And they are not in any of the paths mentioned elsewhere on this forum. All i can find are .dds and .lights files with the thumbnail previews. These don't seem to be the files I need(?) Thanks for any help Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 21, 2020 Report Share Posted August 21, 2020 Hi ! Can be find here C:\Users\username\Documents\3D-CoatV49#___\Panoramas Quote Link to comment Share on other sites More sharing options...
Member Fuzatron Posted August 21, 2020 Author Member Report Share Posted August 21, 2020 Thanks for the quick reply Something must be screwy with my install(?) I searched my drive for other similar folders but still not having any luck Here is the closest I found... Is there another location it could be in? Thanks again for the help! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 21, 2020 Report Share Posted August 21, 2020 Try installing latest version. Quote Link to comment Share on other sites More sharing options...
Member Fuzatron Posted August 21, 2020 Author Member Report Share Posted August 21, 2020 Hmmm... It still didn't show up :/ So i uninstalled previous versions and re-installed... Still not seeing it anywhere though :/ Really stange... Anywhere else they could be? Or some other way to get that garage panorama? Thanks for the help Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 21, 2020 Report Share Posted August 21, 2020 No there isnt... strange, can you see environments inside 3DC suing panoramas panel ? Are you installing on C: ? bus_garage.zip 1 Quote Link to comment Share on other sites More sharing options...
Member Fuzatron Posted August 21, 2020 Author Member Report Share Posted August 21, 2020 Thanks so much for sending it EDIT: Yes they show up and work just fine inside the program I am installing on my D drive. I have user folders on both drives and was checking both drives to be safe... I even ran a search for "panoramas" on both drives but it only pulled up the folder with the thumbnails (inside the application directory).... Let me know if you'd like me to check for them somewhere else or have any questions. But this gets me by for now... Thanks again! 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 21, 2020 Report Share Posted August 21, 2020 You welcome File > Browse > User Data Let you find where the additional folders are located. Quote Link to comment Share on other sites More sharing options...
Member Fuzatron Posted August 21, 2020 Author Member Report Share Posted August 21, 2020 That's strange too... Mine is empty. Doesn't seem to be causing any problems so far though Quote Link to comment Share on other sites More sharing options...
