Member MooOutlander Posted April 29, 2009 Member Report Share Posted April 29, 2009 Hi Andrew. New menu was discovered Ahpha78. It is [Export SL Sculpt map] . But It doesn't happen. How can I do? Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted April 29, 2009 Report Share Posted April 29, 2009 Hi Andrew.New menu was discovered Ahpha78. It is [Export SL Sculpt map] . But It doesn't happen. How can I do? It works only if you have imported SL object before using File->Import SL object Quote Link to comment Share on other sites More sharing options...
Member MooOutlander Posted April 29, 2009 Author Member Report Share Posted April 29, 2009 It works only if you have imported SL object before using File->Import SL object Ok Thanx I try It Quote Link to comment Share on other sites More sharing options...
