Taros Posted May 15, 2009 Report Share Posted May 15, 2009 Hi. I talked with a acquaintance of mine. He is very experienced in skulpting and using tools like ZB and MB from the beginning. He knows the software "claytools", too. He told me about a very nice an productive feature, that could be useful for the current version of 3DC: 1. What about the idea to paint curves on the voxel object and use them like pathes or guides for the brush? The brush could automaticly align/snap to the curve and follow the path. 2. What about another idea with curves: You paint a curve. Then you can "drag" the curvepoints and the voxel-skin follows the curve, the skin should be "sticked to the curve". Then it would be very easy and very effective to make sharp voxel-edges. On the bottom you see my example for the ideas. Quote Link to comment Share on other sites More sharing options...
Advanced Member parel Posted May 17, 2009 Advanced Member Report Share Posted May 17, 2009 Yes! I absolutely agree with that sugestion. That is exactly what I was thinking as well. You should allow the curves to be independent of the surface if needed. This would allow the use of slicks, rakes etc with precision to cut as well as add.. If the curves could also look visualy similar to the lines that you indicate. that would be cool- unlike the current curves implementation, which should almost be included as some kind of sweep command. If the curve creation could be as intuitive as Iheartsketch that would be a dream clay tool. Quote Link to comment Share on other sites More sharing options...
