[Tip] Completely new folders structure
Carlosan
Andrew replied about this:
- Completely new folders structure. Really streamlined and logical as it was proposed in this thread.
Almost all now is split between two folders - data and UserPrefs.
As it is logical,
- UserPrefs is user-created content.
- Data is sort of temporary stuff.
The folder in documents changed, now it is Docs/3DCoat-2021/.
> C:\Users\username\Documents\3DCoat-2021
Even if the folders structure is changed it is compatible with the previous one.
As soon as 3DCoat detects some files copied to the new location in Documents from the old one, it will convert the files to the new structure.
Also, if you will install 3dcpack it will be installed correctly (except presets that use old tools that are not present in the toolset).
So, to migrate from earlier beta you may copy folders from old beta to Docs/3DCoat-2021 or create 3dcpack in old beta and install using UI.
