New Member Singt Posted June 22, 2022 New Member Report Share Posted June 22, 2022 Hi eveyone. I want to ask about sculpting process with flatten tool. For exampe I have such detail in my mesh and I want to fix it with flatten tool: Firstly I tried to find Mask tool to isolate the detail. But there isn't such tool. I used Surface hide. I made some pases with Fill and Flatten tools. Flatten tool made deepenings in closest to corner plases. It means the tool still consider hidden mesh: Finally I unhided all and found out that hidden mesh deformed too, this method doesn't work as masking. So my questions are: 1) how to mask mesh parts to freezing it in surface mode? 2) can Flatten tool or any another tool flatten surfase close to corners without creating unwanted holes? Thanks. Quote Link to comment Share on other sites More sharing options...
New Member Singt Posted June 22, 2022 Author New Member Report Share Posted June 22, 2022 I have solved 1st issue. It's necessary to use Flatten tool with "Ctrl" to fill holes when they appear. But how to make a mask or freez in sutface mode? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 22, 2022 Report Share Posted June 22, 2022 Hi This video is old, but hope it will be helpful Quote Link to comment Share on other sites More sharing options...
Member frmdbl Posted June 22, 2022 Member Report Share Posted June 22, 2022 5 hours ago, Singt said: I have solved 1st issue. It's necessary to use Flatten tool with "Ctrl" to fill holes when they appear. But how to make a mask or freez in sutface mode? For me the flatten tool is pretty useless. Try the preset I posted here to get sharp planar surfaces . 1 Quote Link to comment Share on other sites More sharing options...
New Member Singt Posted August 8, 2022 Author New Member Report Share Posted August 8, 2022 frmdbl, thanks a lot!. Your brush havs another features, I will use it. 1 Quote Link to comment Share on other sites More sharing options...
