Member welcomerobots Posted June 27, 2022 Member Report Share Posted June 27, 2022 (edited) I've found an annoying problem. If I use the modeling select tools I always use these with brush selection mode, because this way I can select faces one-by one. When I switch to select/transform tool, the tool resets selection mode to rectangular what is annoying, because I have to change selection mode after every selection. So I've found a workaround: I stack shortcut T for transform and T for brush selection mode, this way I can double tap T, and problem is solved. But this is not the case, because T defaults to Brush panel, so I've found that I can delete brush panel shortcut with backspace. The problem here, is I can't delete shortcut with backspace permanently, because whenever I switch to another tool, and try to switch back with T for transform tool, and I tap twice, the Brush panel appears again, and the T shortcut reverts back to being the shortcut of the Brush panel. So I am in a loop of bugs now.Short version: can't delete already existing shortcuts. Edited June 27, 2022 by welcomerobots 2 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 21, 2022 Report Share Posted July 21, 2022 Was solved on latest versions, isnt it ? 1 Quote Link to comment Share on other sites More sharing options...
Member welcomerobots Posted July 21, 2022 Author Member Report Share Posted July 21, 2022 Yes! Both features work now! Thank you and thank you for the feedback! 1 Quote Link to comment Share on other sites More sharing options...
Member welcomerobots Posted November 11, 2022 Author Member Report Share Posted November 11, 2022 But Transform tool doesn't save selection mode settings, always revert to the default rectangular selection. This is still an existing problem in the newest version! 1 Quote Link to comment Share on other sites More sharing options...
Member welcomerobots Posted March 14, 2023 Author Member Report Share Posted March 14, 2023 (edited) version 2023.06 3dCoat forget that I deleted shortcut key 'T' from Brush window. Can't set T as transform tool hotkey, can't set Q as transform tool hotkey every key reverst to default after the first usage as assigned to non-default tools. Edited March 14, 2023 by welcomerobots 2 Quote Link to comment Share on other sites More sharing options...
