New Member siet Posted August 26, 2022 New Member Report Share Posted August 26, 2022 Когда рисую нету цвета, только блеск Quote Link to comment Share on other sites More sharing options...
Solution Carlosan Posted August 26, 2022 Solution Report Share Posted August 26, 2022 Hi Channel Toggle Icons on Paint Room 3DCoat has three channels that you can paint at any given moment. Before you’ll find out how each tool works in Paint Mode, you are to know about painting in Depth / Color / Glossiness channels, and also to know about color picking, and types of drawing. This icons will, upon LMB clicking, toggle the channel on or off. If the channel is off, you will see a large “X” over the respective icon. On the right you can see in the image those three icons. They are from left to right: Depth: Use the depth slider to adjust the amount of extrusion to apply while drawing. Use the smoothing slider to adjust the amount of smoothing to apply while drawing with the SHIFT key pressed. To view menu use D. Color: Use the opacity slider to adjust the amount of color to apply. Click to disable color. Use the button determines the rule for the draw color. To view menu use C. Glossiness: Glossiness channel intensity control. Click to toggle Glossiness on or off. To view menu use R. 1 Quote Link to comment Share on other sites More sharing options...
New Member siet Posted August 26, 2022 Author New Member Report Share Posted August 26, 2022 thank you very much! 1 Quote Link to comment Share on other sites More sharing options...
