Member ase.shonk Posted January 14, 2023 Member Report Share Posted January 14, 2023 why for some reason when i try to import FBX model for painting nothing appears even not the import settings Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 14, 2023 Report Share Posted January 14, 2023 Hello Try exporting fbx as binary or ascii. Import both version and check which one works for you Quote Link to comment Share on other sites More sharing options...
Member ase.shonk Posted January 14, 2023 Author Member Report Share Posted January 14, 2023 2 hours ago, Carlosan said: Hello Try exporting fbx as binary or ascii. Import both version and check which one works for you hi! thanks for the reply but sadly the binary or ascii exports did not work and has the same results here is the fbx also Sty;izedEyeHammer.fbx Quote Link to comment Share on other sites More sharing options...
Solution Carlosan Posted January 14, 2023 Solution Report Share Posted January 14, 2023 ah, ok. Its a typo (;) error rename Sty;izedEyeHammer => StylizedEyeHammer 1 Quote Link to comment Share on other sites More sharing options...
