Member kumpa Posted February 16, 2023 Member Report Share Posted February 16, 2023 Since couple of versions ago I am experiencing crash whenever I attempt to open file. It doesn't print anything in the console and I don't know where crash logs are. I am using AwesomeWM and everything was working just fine until a month or so ago. I would really appreciate if you could look int the issue. I tried every subsequent version but none works. From the memory the issue was introduced around version .52 or so Cheers ! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 27, 2023 Report Share Posted February 27, 2023 was this issue solved on latest version ? Quote Link to comment Share on other sites More sharing options...
Member nodespaghetti Posted February 11 Member Report Share Posted February 11 exactly the same problem here, also on awesomeWM but I think it's happened on KDE Plasma, too. using Kubuntu 23.10 gonna try the beta version and see if that fixes it. edit: weirdly, the problem only occurs in the Ubuntu 22.04 version, Ubuntu 20.04 version works great. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 28 Report Share Posted February 28 The compatibility was upgraded to Ubuntu version 20.06 Quote Link to comment Share on other sites More sharing options...
