Advanced Member blackant Master Posted February 28 Advanced Member Report Share Posted February 28 Hi, I don't have the answer yet, I would like to know if someone has already found a tip about this kind of painting? Quote Link to comment Share on other sites More sharing options...
Advanced Member blackant Master Posted February 28 Author Advanced Member Report Share Posted February 28 (edited) My own Tips is to proceed in 2 main steps: The first one is to use a material with a simple line effect as opacity map, and the object must be unwrapped as strip for best result: If the lines are perfect the second step should work like this. Using the Line Tool, target a point from the lines marks in steps 1, at the extremity of the unwrapped mesh (seams). adjust your painting size and click on the next line mark extremity using Texture Editor. Repeat the operation until the End, making the steps one by one. The last step must be done manually because extremities of the mesh cannot use the same logic. Try to approach the maximum parallel line and cleanup manually use paint brush and erase Brush. A This is the most fastest technic I fund to make this . Edited February 28 by blackant Master Quote Link to comment Share on other sites More sharing options...
Solution Oleg_Shapo Posted February 28 Solution Report Share Posted February 28 There is a spiral in Curves. It can be adapted to the surface. We'll have to tinker. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member blackant Master Posted March 6 Author Advanced Member Report Share Posted March 6 Ho, my god, so many years I work with 3dcoat and still so many things I miss !!! Quote Link to comment Share on other sites More sharing options...
