Advanced Member zf3d Posted March 24, 2023 Advanced Member Report Share Posted March 24, 2023 Does 3dcoat support multi udim Due to the need for film and television, multiple UVs and a large amount of detail are required, so one UV region is not enough for baking. How do I set multiple UV regions? 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 24, 2023 Report Share Posted March 24, 2023 Hi 3DC will look at UV tiles as UDIMs, and will allow you to import and export them. The function is currently called "Import UV Tiles as UV Sets". It was called "Import UV Tiles as UDIM", but someone (other than me) changed it back to it's old name. That said, when you import your file, tick the box "Import UV TIles as UV Sets", and it will import all of your tiles and rename them according to their UDIMs. Then also when you're done and exporting, tick the box "Export UV Sets as UV Tiles", this will keep the UDIM imported tiles and the names assigned to them upon import. Technically UV Sets are different than UV Tiles or UDIM, and 3DCoat does not actually support real UV tiling or real UDIM. Using UV Sets is a sort of elegant workaround. Quote Link to comment Share on other sites More sharing options...
