Carlosan Posted April 13, 2023 Report Share Posted April 13, 2023 Quote Link to comment Share on other sites More sharing options...
Advanced Member phoenixart Posted April 15, 2023 Advanced Member Report Share Posted April 15, 2023 @Carlosan Has the Gold Rough material changed? It's much darker on my end In fact, it looks quite bad once applied Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted April 15, 2023 Report Share Posted April 15, 2023 6 hours ago, phoenixart said: Has the Gold Rough material changed? In version 23.15 it seems to look fine Quote Link to comment Share on other sites More sharing options...
Advanced Member phoenixart Posted April 15, 2023 Advanced Member Report Share Posted April 15, 2023 Thanks @Oleg_Shapo I'm using 2023.15 too A couple of things: compared to the tutorial, it looks different in your case too: But at least in your viewport is not as bad as in my case. Perhaps the one in the tutorial was a tweaked version, although that would be confusing for the viewer. Another thing. I tried refreshing the preview, and here's what happened: The material looks completely off. Would you mind sharing your material settings? Here are mine: Quote Link to comment Share on other sites More sharing options...
Advanced Member phoenixart Posted April 15, 2023 Advanced Member Report Share Posted April 15, 2023 And I think other materials look strange too: 2023-04-15 12-17-56_H.264.mp4 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 16, 2023 Author Report Share Posted April 16, 2023 change opacity value to 100 Quote Link to comment Share on other sites More sharing options...
Advanced Member phoenixart Posted April 16, 2023 Advanced Member Report Share Posted April 16, 2023 1 hour ago, Carlosan said: change opacity value to 100 It's already 100% The material looks way darker than the one in the tutorial. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 16, 2023 Author Report Share Posted April 16, 2023 a fresh install using latest version 2023.16 will fix the issue. Quote Link to comment Share on other sites More sharing options...
Advanced Member phoenixart Posted April 16, 2023 Advanced Member Report Share Posted April 16, 2023 7 hours ago, Carlosan said: a fresh install using latest version 2023.16 will fix the issue. It didn't. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 16, 2023 Author Report Share Posted April 16, 2023 This is weird, try another environment please I am shouting in the dark, sorry Quote Link to comment Share on other sites More sharing options...
Advanced Member phoenixart Posted April 16, 2023 Advanced Member Report Share Posted April 16, 2023 30 minutes ago, Carlosan said: This is weird, try another environment please I am shouting in the dark, sorry Would you mind sharing how the material settings look on your end? I'm curious to see if they match. Here are mines: Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 16, 2023 Author Report Share Posted April 16, 2023 SM maps connection are ok ? I am not currently using Cavity RGB on Preferences, but traditional. Quote Link to comment Share on other sites More sharing options...
Advanced Member Featured Comment phoenixart Posted April 18, 2023 Advanced Member Featured Comment Report Share Posted April 18, 2023 It was the HDRI map. None seems to match the one in the video, but at least now I know what was causing that overly dark results. 1 Quote Link to comment Share on other sites More sharing options...
Posted by phoenixart,
1 reaction
Go to this post
