New Member Shay Smith Posted May 1, 2023 New Member Report Share Posted May 1, 2023 Hey everyone! So I'm running into an issue when trying to import my model into 3dc. When importing my model 3dc is splitting one of my UV sets into Body and Body01. The objects of the set are assigned to the same material called Body. I have had no issues when importing the model into Substance Painter, Marmoset, and Maya. I'm not sure what could be causing this and have never seen this issue before. Any help is appreciated! I would rather not have to add another texture set if I don't have to and I'm on a tight deadline. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 1, 2023 Report Share Posted May 1, 2023 Hi ! Try turning OFF this setting 1 Quote Link to comment Share on other sites More sharing options...
New Member Solution Shay Smith Posted May 1, 2023 Author New Member Solution Report Share Posted May 1, 2023 Thanks for the reply Carlosan! That unfortunately doesn't work for me as I have other texture sets with the model and it combines them all together. I did find a solution however! I combined the UV set that was getting split into two with this method and it seems to have worked. 1 Quote Link to comment Share on other sites More sharing options...
