New Member superframe Posted July 6, 2023 New Member Report Share Posted July 6, 2023 (edited) As the title describes. I can select an edge of the retopo object, but when I go to add a new point, it doesn't select a point on the reference object like it was yesterday. video >> Probably something simple. I search around and tried to play with snapping options. Edited July 6, 2023 by superframe video error Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 6, 2023 Report Share Posted July 6, 2023 Try turning OFF Virtual Mirror Mode. On 4/29/2012 at 4:04 PM, TimmyZDesign said: Basically Virtual Mirror Mode is useful because it allows you to work exclusively on one side of your mesh while viewing a virtual preview for the other side. It is a nondestructive method of working, which I really like. It also allows you to snap the edges of polygons along the symmetry line using "mirror snapping". It is a nondestructive method of working, allowing for quick and easy changes to symmetrical models. I prefer to always leave it on during retopo, but it does have one slightly annoying bug: It doesn't work with the strokes tool. The workaround is to turn symmetry off temporarily and delete the unwanted faces it has created. This isn't a big deal, but I will report this bug when I get around to it. FYI, here are two threads about this same exact topic that will probably answer any other questions you might have: http://3d-coat.com/forum/index.php?showtopic=9674&st=0&p=74468&hl=+virtual%20+mirror&fromsearch=1entry74468 and: http://3d-coat.com/forum/index.php?showtopic=9673&st=0&p=74485&hl=+virtual%20+mirror&fromsearch=1entry74485 Hope this help Quote Link to comment Share on other sites More sharing options...
New Member superframe Posted July 6, 2023 Author New Member Report Share Posted July 6, 2023 Hi thanks for this. I found virtual mirror mode under mesh, but it didn't seem to have any effect. I also turned off symmetry. It is like all of the sudden from yesterday to today, it isn't seeing the underlying mesh. Any help appreciated. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 6, 2023 Report Share Posted July 6, 2023 If you have a model on paint room from any early baking step, delete it Quote Link to comment Share on other sites More sharing options...
