Member Kodra Posted August 20, 2023 Member Report Share Posted August 20, 2023 (edited) I know I can use stencil to paint texture, but stencil is a 2D projection. Textured brush tips don't work well either. A single brush stroke works, but it's impossible to paint the whole model with only one continuous stroke, and the texture doesn't look evenly where multiple strokes overlap. Fill Tool doesn't work either. Because the model's UV density is not even, and Fill Tool's noise can only apply in UV space or via Cube mapping. If it has a triplanar mapping it would be so great... There must be a way to apply textures evenly, but I just can't figure out how. Edited August 20, 2023 by Kodra Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 20, 2023 Report Share Posted August 20, 2023 There are no UV's in the Sculpt room. Objects are just way too dense for that. But 3DCoat can bake the diffuse color from an image map onto the vertices of the model (polypaint). Related Quote Link to comment Share on other sites More sharing options...
Member Kodra Posted August 21, 2023 Author Member Report Share Posted August 21, 2023 3 hours ago, Carlosan said: There are no UV's in the Sculpt room. Objects are just way too dense for that. But 3DCoat can bake the diffuse color from an image map onto the vertices of the model (polypaint). Related Thank for the reply. Sorry, I didn't make it clear enough. I was talking about Paint Room, not Sculpt Room. The mesh is imported, and it has UV already. Quote Link to comment Share on other sites More sharing options...
Solution Carlosan Posted August 21, 2023 Solution Report Share Posted August 21, 2023 Sorry my bad. Fill with cube mapping it is not helpful ? 1 Quote Link to comment Share on other sites More sharing options...
Member Kodra Posted August 21, 2023 Author Member Report Share Posted August 21, 2023 Ah I see. I misunderstood what Cube Mapping is. I was looking for a triplanar mapping option, but actually Cube Mapping is triplanar mapping in 3DCoat. Thank you very much. 1 Quote Link to comment Share on other sites More sharing options...
