Hi 3DCoat Community! I'm running into an issue when trying to install the software onto /opt/3DCoat-2023.37 and then creating a symlink to /usr/local/bin.
What's Working?
The good news is that the program does launch from the Nemo File Manager when located on my $HOME path with no issues when launching it using the 3dcoat-Ubuntu20.04 binary.
Not Working
It produces the following error when trying to launch the symlink from /usr/local/bin/3dcoat after executing
3dcoat: error while loading shared libraries: libtbb.so.2: cannot open shared object file: No such file or directory
This is probably because of environment variables being missing. I've tried hunting down the forum but the link for the linux shortcut pdf/documentation is not available (404 HTTPS status code):
Question
mikeyjoel
What's Working?
Not Working
ln -s /opt/3DCoat-2023.37/3dcoat-Ubuntu20.04 /usr/local/bin/3dcoat
http://pilgway.com/~sergyi/LinuxDocs/LinuxShortcut.pdf
It does crash when attempting to select a sculpture surface if executing 3dcoat-Ubuntu22.04 on LMDE 6.
System Summary
OS: LMDE 6 (faye)
KERNEL: 6.1.0-13-amd64
CPU: Intel Core i9-9900K @ 3.60GHz
GPU: NVIDIA GeForce GTX 1070
GPU DRIVER: NVIDIA 525.125.06
RAM: 32 GB
Thank you all in advance!
Edited by mikeyjoelLink to comment
2 answers to this question
