3DCoat Sculpt tool "Replicator" | Gorbatovsky
Carlosan
I just updated version 2024.07 where it says this tool was introduced.  However, I cannot find it under objects in the Sculpt Room as shown in the video.  Was it placed somewhere else?
  • Confused 1
Yes, is under Object on voxel and surface mode
Try resetting to default. Sometimes it solve the issue.
I also did a clean install and that did not fix the problem.  I was however able to complete 2024.07 update my laptop the Multiple Objects available  in the Objects panel.
1 hour ago, AbnRanger said:
I had the same problem. Try this...close 3DCoat > open MY DOCUMENTS/3DCOAT/USER PREFS/ROOMS >delete or temporarily rename the CUSTOM ROOMS folder.
There was/is something in the Custom Rooms configs that makes it not appear. Hopefully that will get fixed in the next build.
  • 2 weeks later...
Multiple Objects tool was renamed to Replicator tool
This tool can be found under Objects Category on Sculpt Room
  • 3 weeks later...
  • 3 weeks later...
  • 1 month later...
Carlosan
insignet was awarded the badge 'Great Support' and 1 points.
On 3/19/2024 at 9:31 AM, Carlosan said:
Hi - with this tutorial the 'Build Surface' is cool. However on build 2024.19 if you go to the Nurbs room and use the 'surface to mesh' I get a instability warning and immediate crash every time. This is a really cool feature, please look into it. I create the surface and select surface to mesh and click ok. The instability warning and then the crash dialogue.
Crash replicated and reported.
Thanks for point it up
Thanks for the answer. It was a temporary tool. I even removed it from my menu.
  • 2 weeks later...
Hi Just tested the latest update 2024.20 - Its says the Surface to Mesh Bug is fixed, but i get the same instability warning and instant crash. I've attached the 3DC file sirf.3b
sirf.3b
  • 2 weeks later...
Modelling Room Profile types... Does anyone know where these Profile Types are located. Can I make my own? We currently have these (see attached), I'd like to see if can make one - if possible. Thanks
31 minutes ago, insignet said:
Can I make my own?
We will add this feature in the future.
Currently you can use the Surface Swept tool
  • 2 weeks later...
52 minutes ago, erikals said:
Looks great,
Thank you, it seems to me that the tool turned out to be very complex.
We still need to add a hint.
  • 1 month later...
@Gorbatovsky Could you help? Working with curves in the Modelling Room. I cannot get the 'cut' curves tool to work. I think it supposed to work like a Knife tool to click and drag across existing curves to split them? Nothing happens (build 2024.26) Also with same build, the Pen circle tool works, but if you delete all previous curves and re-select the Pen Circle (with no active curve layers present) it does not show the Pen radius, you have to click the 'on Plane' checkbox for it to work?
2 hours ago, insignet said:
Could you help?
Circle Tool - Pen draws a circle equal to the diameter of the pen.
The normal of the circle plane is perpendicular to the screen plane or parallel to the surface normal or the normal of the working plane (if it enabled)
This tool is create slice of sculpt mesh or low poly mesh.
