Member oiver55 Posted August 30, 2024 Member Share Posted August 30, 2024 (edited) I want to import this material that I downloaded from Quixel. When I got to install Quixel Asset as Smart Material it is expecting a zip file, however my downloaded Quixel material is not a zip file. Am I suppose to make a blank Smart Material and import the maps from scratch? Is that how you guys do it? If thats the case then what is the install Quixel Asset for? I attached a screenshot of what the downloaded material looks like from quixel bridge. Edited August 30, 2024 by oiver55 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 30, 2024 Share Posted August 30, 2024 Hi Inside 3DCoat (from version 2023.40+), you can add the additional Quixel folder by following these steps:1. Open 3DCoat.2. Go to the Edit > Preferences.3. Navigate to `Input/Output` tab.4. Here, you should see an option for `Additional Quixel folder' 5. Set the path to where you're Quixel folder materials are and hit apply and close. Restart 3DCoat and you will be welcomed with the following: Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 1, 2024 Share Posted September 1, 2024 Also can use this other option for future needs ------------------------------------------------ Add existing materials folder. Add the Smart materials from an existing folder. A new Materials folder with the same name will be created. Select at least one file to automatically add all the files from the folder to the list. This is the complete list of aliases (at the end of the filename) used to recognize the texture usage: Bump: _DEPTH, _BUMP, _DEEP, _DISPL, _DISP, _DISPLACEMENT, _D Normal map: _NMAP, _NM, _NORMAL, _NORMALMAP, _NORM, _NORMALS, _N Color: _COLOR, _CLR, _DIFFUSE, _ALBEDO, _CL, _RGB, _DIF, _C Gloss: _SPEC, _GLOSS, _GLOSNESS, _GLOSINESS, _GLOSSNESS, _GLOSSINESS Roughness: _ROUGH, _ROUGHNESS, _R Clip mask: _MASK, _MSK, _MS, _CLIP, _ALPHA Metalness: _MET, _METAL, _METALL, _METALLICITY, _METALICITY, _METALNESS, _METALLNESS, _MT, _ME, _METL Ignored: _PREVIEW, _PREV, _TMB, _THUMBNAIL, _PRV, _AO, _OCCLUSION The any of . – ~ may be used instead of the _ sign. If any map is named with a space in the name, the texture is assigned as new Smart Material. Quote Link to comment Share on other sites More sharing options...
