Member paololobbia Posted August 13, 2009 Member Report Share Posted August 13, 2009 Hi Andrew, In a program called Artrage 2.5 i use stencils and rulers to draw a fluid pencil stroke in 2D. A link shows the artrage manual,just click on Using Stencils and Rulers to go on page 74: http://www.scribd.com/doc/3677837/ArtRage-2-5-Manual So in 3dCoat,returning back from retopo mode to voxel model,is it possible to use the retopomesh edges as guides to control the direction of the voxelpen? An example attached: Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted August 13, 2009 Report Share Posted August 13, 2009 Now you can't do that exactly. But you can for example use curves in "Run pen along spline" mode to achieve better precision. Quote Link to comment Share on other sites More sharing options...
