Retopology for armor :
I have a character , i want ot make separate parts like an armor !
Instead of using voxel copy to make the armor : it's slow on my computer :o *
It is possible to make retopology on voxels , than turn back the retopoly mesh to voxel scene as a separate voxel object ?
Ok, the cut and clone tool really rocks :)
In fact it must be used with default voxel resolution.
If you increase too much resolution , the tool will be too slow ! so it must be used at beginning witout any resolution increase if you plan to
make several objects with cut and clone.
Cloth tool+retopology tools = much fun.(hold ctrl if you want negative merge,negative extrusion values does not work.)
Drawing a few quads aint much longer than some bezier splines :) (use subdivide to smoothen curves).
