Advanced Member Ratchet Posted August 21, 2009 Advanced Member Report Share Posted August 21, 2009 I have a character , i want ot make separate parts like an armor ! Instead of using voxel copy to make the armor : it's slow on my computer * It is possible to make retopology on voxels , than turn back the retopoly mesh to voxel scene as a separate voxel object ? Quote Link to comment Share on other sites More sharing options...
Advanced Member Ratchet Posted August 22, 2009 Author Advanced Member Report Share Posted August 22, 2009 Ok, the cut and clone tool really rocks In fact it must be used with default voxel resolution. If you increase too much resolution , the tool will be too slow ! so it must be used at beginning witout any resolution increase if you plan to make several objects with cut and clone. Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted August 22, 2009 Contributor Report Share Posted August 22, 2009 Cloth tool+retopology tools = much fun.(hold ctrl if you want negative merge,negative extrusion values does not work.) Drawing a few quads aint much longer than some bezier splines (use subdivide to smoothen curves). Quote Link to comment Share on other sites More sharing options...
