Advanced Member GeeJay Posted December 18, 2009 Advanced Member Report Share Posted December 18, 2009 Hi, I would like to suggest adding blended box mapping as a fill type to the fill tool. What it does is use standard cube mapping but with blended edges so you don't have to worry about seams. It is a great way to add an irregular layer like noise or grunge over the model. It is described in detail here. I am under the impression it would be easy to implement as the mapping functionality is already there. Ideally it would support picking additional maps for each side of the cube. If there is a way to do something like this already using the provided tools I would like to hear about it. Cheers, George Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted December 18, 2009 Contributor Report Share Posted December 18, 2009 Hi, I would like to suggest adding blended box mapping as a fill type to the fill tool. What it does is use standard cube mapping but with blended edges so you don't have to worry about seams. It is a great way to add an irregular layer like noise or grunge over the model. It is described in detail here. I am under the impression it would be easy to implement as the mapping functionality is already there. Ideally it would support picking additional maps for each side of the cube. If there is a way to do something like this already using the provided tools I would like to hear about it. Cheers, George There is already nice seamless cube-mapping in Fill tool. Just select Add Custom as Modulation type,there you can create custom filling :look for 'Mapping type' parameter ,there you can choose Cube-Mapping. Happy Coating Quote Link to comment Share on other sites More sharing options...
Advanced Member GeeJay Posted December 21, 2009 Author Advanced Member Report Share Posted December 21, 2009 Yes that works quite nicely. Thanks! Quote Link to comment Share on other sites More sharing options...
