Member designamyte Posted October 21, 2010 Member Report Share Posted October 21, 2010 Hello, i was sculpting all the time in the surface-mode, because it is faster than vox.-mode. I only switch to that other mode if i need new geometry or so. I think it would be nice if you switch from the surf.-mode to the vox.-mode with your sharp edges. Now it rounds up the edges, because it resurfaces the geometry, i guess. You can go higher in vox.-mode, but this would slow down your machine, extremly. So it would be cool, if there can be a checkbox with "keep your sharp edges" or something like that. If it´s possibly, from the technical aspect. cheers de. Quote Link to comment Share on other sites More sharing options...
Taros Posted October 23, 2010 Report Share Posted October 23, 2010 I guess, this is not possible as long as you don't have the right voxel resolution selected. The sharp edges in the surface mode will be always smoothed, because 3DC generates a new voxel cloud based on your polymesh in the surface mode. Quote Link to comment Share on other sites More sharing options...
Member designamyte Posted October 24, 2010 Author Member Report Share Posted October 24, 2010 Hi, thank you for reply. I think you are right, but i thought it would be nice, if the "vox-cloud" get that sharp poly-edges, get the old "vox-cloud". As you say, currently it seems not possible, technicaly... greetings de. Quote Link to comment Share on other sites More sharing options...
Contributor BeatKitano Posted November 14, 2010 Contributor Report Share Posted November 14, 2010 I guess, this is not possible as long as you don't have the right voxel resolution selected. The sharp edges in the surface mode will be always smoothed, because 3DC generates a new voxel cloud based on your polymesh in the surface mode. Are you sure it's not possible ? Like an angle estimation done on surface mode, if angle > x (x is the limit specified by the user): don't change the point cloud on the affected part when we switch back to voxel mode ? Quote Link to comment Share on other sites More sharing options...
