Advanced Member wailingmonkey Posted February 12, 2008 Advanced Member Report Share Posted February 12, 2008 Hi Andrew, Just thought this might be another feature you could consider to further enhance (and set above) 3d-brush from it's competitors. Basically, a means to have a grid overlay system based on the camera projection, along with rulers (now that you've already got that handy measuring tool) and the ability to snap-to-grid either curve spline points and/or brush-strokes themselves (not sure about this one). Also, the ability to allow the user to set the grid unit spacing. Ideally, symmetry would work with this as well... I'm thinking along the lines of Photoshop in terms of functionality, but in 3D, of course. Kind regards, wailingmonkey Quote Link to comment Share on other sites More sharing options...
Advanced Member wailingmonkey Posted February 23, 2008 Author Advanced Member Report Share Posted February 23, 2008 Hi Andrew, I'm really liking the grid setup you've implemented. I was wondering if you might consider some enhancements, namely: - ability to rotate the grid similar to materials (and snap at horizontal, vertical, and 45-degrees, or even set a rotation angle from 0-360) - allow for 'Paint with Rectangle' and 'Paint with Elipse' to snap to the grid as well (for instance, if you want to create rectangles along specific grid lines, or you want elipses to fit between certain grid lines cheers. wailingmonkey Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted February 23, 2008 Report Share Posted February 23, 2008 Good and easy to do ideas. Will do that. Quote Link to comment Share on other sites More sharing options...
Advanced Member wailingmonkey Posted February 23, 2008 Author Advanced Member Report Share Posted February 23, 2008 nice. thank you. I also thought of something else, unrelated... would you be able to add the ability to erase with the 'Draw with Spline' tool? (this can mostly be done via erase and 'Paint with Spline', but adding it as a checkbox in 'Draw with Spline' as 'Erase with Spline' might be handy too.) Quote Link to comment Share on other sites More sharing options...
