Member nexust56 Posted July 23, 2011 Member Report Share Posted July 23, 2011 Hey guys, Does anyone know how to select and add the highpoly and lowpoly in different layers so I can switch btw them. Quote Link to comment Share on other sites More sharing options...
Psmith Posted July 23, 2011 Report Share Posted July 23, 2011 Can you explain what you need a little more thoroughly? Greg Smith Quote Link to comment Share on other sites More sharing options...
Member nexust56 Posted July 26, 2011 Author Member Report Share Posted July 26, 2011 Hi, Sorry if I wasnt clear, Im doing retopo and trying to add the highpoly(from zbrush) and the new lowpoly in different layers so I can switch btw them to see the silhouette. Quote Link to comment Share on other sites More sharing options...
Psmith Posted July 26, 2011 Report Share Posted July 26, 2011 The way 3D-Coat handles things is for the "Merged" hi-poly mesh to be converted to voxels, first - which can then be used as the "background" or surface upon which all Retopo operations are conducted. The simplest way to get started is to use the opening "Wizard", hover your mouse over the "Voxel" section and choose the file folder icon to select your Zbrush mesh. Use the "Translate" tool to scale up the merged mesh so it has sufficient resolution to capture the details you need. Then, go to the "Retopo Room" or tab and use the tools you need to get the job done. Your original mesh is displayed as a shaded "background" object. Greg Smith Quote Link to comment Share on other sites More sharing options...
Javis Posted July 27, 2011 Report Share Posted July 27, 2011 Another way you could do it, is to import the mesh from ZB as a reference mesh (which works great for high poly meshes), and then use the retopo room. This eliminates the need for converting to voxels, if, and I'm assuming here, that you do not wish to sculpt further details using voxels. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted July 27, 2011 Reputable Contributor Report Share Posted July 27, 2011 The way 3D-Coat handles things is for the "Merged" hi-poly mesh to be converted to voxels, first - which can then be used as the "background" or surface upon which all Retopo operations are conducted. The simplest way to get started is to use the opening "Wizard", hover your mouse over the "Voxel" section and choose the file folder icon to select your Zbrush mesh. Use the "Translate" tool to scale up the merged mesh so it has sufficient resolution to capture the details you need. Then, go to the "Retopo Room" or tab and use the tools you need to get the job done. Your original mesh is displayed as a shaded "background" object. Greg Smith Greg, this was discussed a little bit when that 3D Coat Review was written recently, and I think it deserves repeating...Can we get an Autopo Button in the Retopo toolbar, so that it's much easier and more logical to find for trial users or newcomers? Maybe create it's own Subsection of the tools, like CREATE, UV and TWEAK? This way, you can add all the options that are in the Vox Tree (right-click) menu. Quote Link to comment Share on other sites More sharing options...
