Member krazypoe Posted February 13, 2012 Member Report Share Posted February 13, 2012 Hey all -- When using the stroke tool, I want the slices to be just on the surface and not go all the way to the center of the model. In other words, when I use the slice tool, it recognizes the middle of the model and slices it. (see picture) WHAT IT'S REALLY DOING ! Is there a way to get the guidelines to recognize only the outer most surface? (without drawing them on manually with the green guidelines) Thank you! Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted February 13, 2012 Reputable Contributor Report Share Posted February 13, 2012 Well, sometimes those are helpful...sometimes not so much. What you can do to fix that is simply click on the strokes that you do not want, and once they are highlighted in white, you can just hit the DELETE key. They're gone. Quote Link to comment Share on other sites More sharing options...
Advanced Member manticor Posted February 13, 2012 Advanced Member Report Share Posted February 13, 2012 i agree .highly annoyin.there should be an option for only outer surface. Quote Link to comment Share on other sites More sharing options...
Member krazypoe Posted February 16, 2012 Author Member Report Share Posted February 16, 2012 Boo, well thanks for the replies. Quote Link to comment Share on other sites More sharing options...
