Advanced Member castaneda Posted July 23, 2016 Advanced Member Report Share Posted July 23, 2016 Wondering if I'm experiencing a bug or not adjusting move tool effectively. When I use the move tool it stretches the mesh horribly. This happens in surface mode as well as voxel mode. Is anyone else experiencing problems with the move tool? I'll upload a couple examples of what happens when the move tool doesn't work as needed. Also, I find that the move tool doesn't grab edges of openings well at all. It tends to mangle the mesh. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 25, 2016 Report Share Posted July 25, 2016 which are your move tool settings ? Quote Link to comment Share on other sites More sharing options...
Advanced Member castaneda Posted July 27, 2016 Author Advanced Member Report Share Posted July 27, 2016 Actually, it mangles the mesh on all settings for the move tool. Whether its a hundred percent move degree or 50 percent it doesn't matter. And all other settings. When I use 4.0 version of 3 d coat, the move tool never does that. Thats why i think it might be a bug of some sort. Thanks for the reply, Carlosan. Quote Link to comment Share on other sites More sharing options...
New Member BenKG Posted July 31, 2016 New Member Report Share Posted July 31, 2016 Was having the same issue but this worked for me... Select the Move tool then press 'E' and uncheck 'ignore back faces'. Hope that helps! 2 Quote Link to comment Share on other sites More sharing options...
Advanced Member castaneda Posted August 6, 2016 Author Advanced Member Report Share Posted August 6, 2016 thanks BenKG. Didn't think of that. Ill see if that is it. Quote Link to comment Share on other sites More sharing options...
